It is currently Wed Mar 04, 2015 5:14 pm
 Post subject: XP Install Help
PostPosted: Sat Aug 21, 2004 8:47 am
I am trying to install xp home on computer for my brother-in-law. It is a fresh install and I used the Seagate utl disk that came with the drive to fromat.
When I put the xp install disk in it loads some files (about 10sec worth) and then says: setupdd.sys could not be loaded error code 4.
Then if I let it reboot and try and boot from the cd it says ntldr is missing.
I am trying to get this done by tonight so he can take it with him college so I need help asap.
thanks,
radbrad
p.s. when did the forum move, I haven't been around in awhile
PostPosted: Mon Aug 30, 2004 9:12 am
Have you wiped cd clean? Sounds like a scratch to me.
PostPosted: Mon Aug 30, 2004 9:58 pm
try the partition and reformat again option, only this time do it with the winxp cd and see what you come up with.
PostPosted: Wed Sep 01, 2004 7:26 am
also clean you installation cd
