It is currently Sun Mar 29, 2015 2:47 am
 Post subject: windows sounds
PostPosted: Thu Aug 19, 2004 8:07 am
I know this is not the place to post but I will try any way. I am looking for windows sound wavs like shut down, command keys, etc
Thank You
Ed
 Post subject: Re: windows sounds
PostPosted: Thu Aug 19, 2004 10:35 am
I'd rather be modding!
Thank You
Ed
This is probably ok to post here since its not really a problem you are trying to fix.
Have you tried google? Or are you actually looking for the ones that are already supposed to be on your drive?
Manta
 Post subject: windows sonds
PostPosted: Thu Aug 19, 2004 1:56 pm
I am looking for ones other then the ones that came with XP. I did a search came up blank. I had a bunch when I was running windows ME but when my computer crashed I lost them all. Thanks
Ed :cry:
 Post subject: Re: windows sonds
PostPosted: Thu Aug 19, 2004 4:00 pm
Ed :cry:
Well, I think those are .wav files - so do a search for those. You are looking for "windows .wav themes or sounds"
Sorry I can't help more - in a rush.
Manta
PostPosted: Fri Aug 20, 2004 11:23 am
LOL. Honestly - I longed for the older second party desktop themes that were created for win98 (just the sounds), and I found the easiest way to get the wavs was just to download the themes and extract them, and just get the wave sounds. I had some cool win98 themes back in the day, and created about 11 of them myself and had a few posted a ways back. They are not up anymore but I have many older themes still that used to go into the old 98 directory. I get the sounds off of those. Too many sounds are annoying though. I just use a few. The Nullsoft sound app that came on the last MaxPc CD was terribly lame though. It often uses 4-7% CPU utilization and has only one preset non-changeable sound scheme (if you want to call it that). I have a custom WarGames sound theme that I created too from sounds clips off of the movie. Remember the move WarGames? :)
PostPosted: Fri Aug 20, 2004 11:33 am
Folding Master (Top-ranked)
Thank You
Ed
I worked with a guy who recorded his window startup sound.
Sherly get me a beer
PostPosted: Sat Aug 21, 2004 12:14 am
Good Morning Tobyrama
How can I get the wavs of my other computer which is running windows 98
Thanks Ed :roll:
PostPosted: Sat Aug 21, 2004 12:33 am
Thanks Ed :roll:
copy&paste...they're stored in c:\windows\media
PostPosted: Sat Aug 21, 2004 12:38 am
Thanks Ed :roll:
^ That's it :)
PostPosted: Sat Aug 21, 2004 2:52 am
Thanks for the help.
Ed
PostPosted: Sat Aug 28, 2004 6:00 am
Hey try recording your own ones like guitar riffs or for boot up just yell BOOT UP in the microphone and record it with windows built in recorder
