It is currently Wed Jan 28, 2015 10:23 pm
 Post subject: Windows 7 or Windows 8.1 for HTPC computer
PostPosted: Mon Jul 28, 2014 8:51 pm
So I'm building a new HTPC system and was wondering if there is any major advatange of going with Win 8.1 over Windows 7. I have both licenses to choose from (spare OEM copies that I haven't installed on any machines yet...)
Both are the non-pro versions, but I think they both have multimedia functionality. I also remember someome telling me that Win8 used slightly less resources than Windows 7?? Anyway, I don't have a touch screen either, so that's not a decision point.
Any suggestions? I do have a lot of ripped Blu-Rays in raw form (not compressed) that I'd like to be able to play, so if that persuades any suggestions...
 Post subject: Re: Windows 7 or Windows 8.1 for HTPC computer
PostPosted: Mon Jul 28, 2014 9:10 pm
Resources won't matter, the computer can comfortably live on 2GB for both. However, Windows 8 needs a bit of work to get Windows Media Center, if that's your 10 foot interface of choice.
PostPosted: Tue Jul 29, 2014 9:30 am
Win7
Only Win8.1 Pro has MC. You can either buy a upgrade Win8. to 8.1 Pro with MC or if you have Pro purchase MC from MS Store.
So it seems to me that Win7 makes more sense for you.
Blu-Ray playback presents its own issues if using a PC BR drive and will require a 3rd party playback app. Also potentially some hardware issues (ex: HDCP) that some of these 3rd party apps get around.
PostPosted: Tue Jul 29, 2014 9:54 am
Alternativly you could say blah to both and use XBMC
PostPosted: Tue Jul 29, 2014 9:58 am
That would be my thinking.
PostPosted: Mon Aug 18, 2014 1:58 pm
Just FYI XBMC will have a new name on the next version called Kodi:
http://xbmc.org/download/
