It is currently Tue Mar 31, 2015 10:02 pm
 Post subject: KNow anything about video editing?
PostPosted: Fri Jun 13, 2014 12:12 pm
Didn't see a multimedia discussion sub-fora so...
Anyway, I got some home videos off my Hi8 cassettes using the convoluted way of a DVD-recorder box to capture the RCA output. So the DVD-recorder gives me output in Video_TS files (.vob). I used Handbrake to convert them to an MP4 file, however, I think I didn't set the settings right. I wanted to use OpenShot to edit the files but it gives me an error about H.264 and B-frames (I think). So it won't load it properly.
So basically, can someone tell me all this encoding mumbo-jumbo and formats and stuff?? It's too complicated right now.
My second option is to try the Windows Movie Maker, so I'll do that soon.
 Post subject: Re: KNow anything about video editing?
PostPosted: Tue Jun 24, 2014 11:03 am
...since you are thinking of using Windows Movie Maker, check these out:
http://billyclyde.hubpages.com/hub/Wind ... -Made-Easy
http://www.windowsmoviemakers.net/Forums/Default.aspx
PostPosted: Thu Oct 09, 2014 5:37 pm
Windows movie maker also can not load mp4 file as I know.
PostPosted: Fri Oct 10, 2014 12:18 pm
http://www.maximumpc.com/article/featur ... _handbrake
