It is currently Mon Jan 26, 2015 1:17 am
 Post subject: Any MS Excel gurus on here?
PostPosted: Sun Jun 01, 2014 8:32 pm
I have a question regarding using Data Validation to add multiple entries to one cell, I will describe below. But I would also like to know if anyone knows of a great Excel forum that I can use to ask questions like the one below. I currently belong to excelforum.com and they give sometimes helpful but basic knowledge. To get the real good help one has to pay a subscription fee.
Is it possible to create a formula using a Data Validation List where it will add a new entry to the existing entries in a cell?
For example: I have a data validation list with the names of Pete, Chris, Bruce, Carly, Megan, and Becky. With the normal data validation set I can select one entry and it will be output into the designated cell. E.g. If I select Bruce then Bruce with be placed in the cell.
Is it possible to set it up so that each time I click on data validation it will add an entry to the already existing entry? E.g. I have already selected Bruce then I decide to add Becky, I want the output cell to show both Bruce and Becky.
I know I can do this with a formula that will place all the results from different cells into a single cell, but I would then have to create multiple data validation entries of which I would rather avoid if possible. Not to mention I don't remember how to do this formula anyway......
Bruce
 Post subject: Re: Any MS Excel gurus on here?
PostPosted: Sun Jun 01, 2014 9:02 pm
A quick Google search points me to this requiring a VB script to work.
PostPosted: Mon Jun 02, 2014 11:01 pm
Yes, that is true. Someone on the forums who actually knows what he is doing with VBA is helping me out. I should have my problem solved soon enough.
Bruce
PostPosted: Sat Jun 21, 2014 7:27 am
If this is being done through a forum, or can be easily communicated here, please keep us updated - I'd be interested in it for my work, too.
Thanks!
PostPosted: Sat Jun 21, 2014 8:05 am
Well, the guy that was helping me, gave up, or at least I presume he did. The code he gave me had to be tweaked a few times and on the last problem I reported he hasn't responded. So I am assuming you can't actually do it. If you would like I can give you the examples he posted and you can see what you can do with it.
PostPosted: Sat Jun 21, 2014 3:13 pm
I reread your example and put up a Google search on that just for funs.
I came up with this: http://exceltactics.com/combine-data-mu ... -one-cell/
Though this might not be what you're looking for, since it's combining cells that share a common attribute. Otherwise I used this search query https://www.google.com/search?q=excel+p ... +same+cell
PostPosted: Sat Jun 21, 2014 7:48 pm
I already know about Concatenate, and that is my alternative method that I am using. Though to use that I had to create another set of cells with validation lists for the list for the concatenate formula. I was trying to find a way to avoid making those extra validation lists. I used different search queries and could not find anything without the use of VBA, which is why I went to that excel forum. Thanks for the suggestion though.
Bruce
PostPosted: Tue Jun 24, 2014 10:54 am
Here is a forum I found for Excel:
http://www.mrexcel.com/forum/forum.php? ... ab1eb4f39b
Looks like you can ask any question under the sun and get an answer.
PostPosted: Tue Jun 24, 2014 5:39 pm
Cool, that looks like a good forum. And it's free. I will see what they come up with.
Thanks Nastyman!
Bruce
