It is currently Sun Mar 29, 2015 11:41 am
 Post subject: PC won't load desktop
PostPosted: Wed Jan 29, 2014 10:01 pm
Hi all, my pc will not load past the log in screen. I can start task manager, then open applications from there, but it's very annoying. When I log in, I am met with a black screen and can only see my cursor (which I can move). Reinstalling windows7 has done nothing, and at one point, stops and the screen goes black again. Also, when I press F8 when starting, Repair your computer doesn't even show up. I've scoured the internet for solutions and have even asked multiple places on reddit and on tomshardware forums. I thought I would try here. Thanks
 Post subject: Re: PC won't load desktop
PostPosted: Thu May 08, 2014 12:31 am
I have seen some computers with problem seeing the desktop icons before.
Once login, the computer reboots.
If this is the same situation you have, I would suggest we format the HDD before the reinstallation.
Please back up the data first if needed.
If still the same problem after format and reinstalling of the OS, I would suggest boot the OS in safe mode.
If safe mode works, then we need to check the hardwares on the computers including the video card, RAM...etc.
Hope this helps.
Bill
Tech Manager, WPTinc. :D
