It is currently Sun Mar 01, 2015 9:14 pm
 Post subject: windows 8.1 app store problem
PostPosted: Fri Oct 18, 2013 6:22 pm
I upgraded from windows 8 to 8.1, and now I can't access the Windows app store. When I click on the tile, it flashes once and then goes back to my desktop (I have Start8 installed). Never had this issue before.
Any suggestions?
 Post subject: Re: windows 8.1 app store problem
PostPosted: Sat Oct 19, 2013 10:32 am
File a bug report with MS.
PostPosted: Sat Oct 19, 2013 7:07 pm
I found this solution, which worked. Run the following in a Command Window to re-register the Store app:
powershell -ExecutionPolicy Unrestricted Add-AppxPackage -DisableDevelopmentMode -Register $Env:SystemRoot\WinStore\AppxManifest.xml
Users browsing this forum: mrmarrero and 3 guests
