It is currently Mon Jan 26, 2015 8:10 pm
 Post subject: Folder Size sorting and display in Win8.1
PostPosted: Sat Oct 05, 2013 1:33 pm
No, I'm not viewing the files in a library, I'm looking at them in C:\Windows\Users\myusername\documents. Folder size isn't displayed the size column. I can view the size by rmb > Properties, but it has to calculate the size every time. Free Commander refuses to sort folders by size. I can use Folder Size 2.9.0.0 to scan the drive, and there's probably a bunch of other third party applications that can do it. But still. This is like Windows usage 101.
 Post subject: Re: Folder Size sorting and display in Win8.1
PostPosted: Sat Oct 05, 2013 4:33 pm
So... what's the question? Well the reason why it doesn't do folder sizing is because if you were at the root directory of the hard drive, you'd have massive amounts of I/O work to calculate everything, for information that isn't quite that useful to be honest.
If you were looking for what's taking up your space, a program like WinDirStat is very useful here.
PostPosted: Sun Oct 06, 2013 9:34 am
Are you thinking of this?
PostPosted: Sat Oct 19, 2013 10:37 am
I already mentioned Folder Size, yes, that's the one I'm referring to; windirstat does the same thing except it's open source and has more details when displaying files that Folder Size would normally display only as "other". I was using the information to decide which folder in the 2TB drive I should start sorting through first, but went with a different strategy of setting a headquarters folder and copying files into it.
