It is currently Wed Jan 28, 2015 8:49 am
 Post subject: Windows 8.1 AHCI
PostPosted: Sat Nov 02, 2013 1:24 pm
Well i have an ssd and did a fresh install to windows 8.1 currently my bootimes seem sluggish. I have checked as ssd and it says im ok. i have checked all my settings.. my registry entry for start is 0 and my error correction is 3. I have checked device manager and it tells me that i have 2 seperate ahci drivers..
and that is my question do you think the standard ahci drivers and amd drivers being on my machine at once is causing issues. cause it just seems slow for ahci..
even though my as ssd readings matched close to my projected for my ocz agility 3.
 Post subject: Re: Windows 8.1 AHCI
PostPosted: Sat Nov 02, 2013 10:15 pm
1. Make sure SSD firmware is up to date.
2. Try different cables and ports.
3. Update BIOS revision to most current.
4. Are the chipset drivers the most current?
5. Do a CMOS reset per MB manual.
6. Since your test app seems to verify around the predicted speed did you clean install the OS?
