It is currently Sat Apr 25, 2015 7:46 am
 Post subject: Recommend driver update software
PostPosted: Wed Feb 22, 2012 9:32 am
Need: recommendations for good utilities for updating drivers in Win7. Partial to freeware, of course :mrgreen:
 Post subject: Re: Recommend driver update software
PostPosted: Wed Feb 29, 2012 10:19 am
The only drive you really need to update is the GPU, which if you remind yourself every two months to check, you should be fine. All the other hardware rarely, if ever, gets a driver update.
PostPosted: Thu Mar 15, 2012 9:34 pm
What kind of driver you are looking for
PostPosted: Sat Mar 17, 2012 7:42 am
If you go to windows update and do the custom option, it will tell you which drivers are recommended to be updated. Don't use windows to update any drivers, always write down the drivers that need updating, then go to the manufactures website and get the latest driver. Unload the old driver and install the new driver yourself, that way there is a clean install and not a new driver installed over the old driver which sometimes causes corruption of the installed driver. This goes double for Video drivers!
PostPosted: Mon Mar 19, 2012 7:15 am
Thanks for the tip. By the old aphorism "If it ain't broke, don't fix it"
I only want to update those drivers that really "need" updating
(of course, it's not clear to me which those are, and the definition of "need").
For gaming I understand prompt update of video card drivers is important,
but I don't know about things like main board chipset drivers, BIOS, etc.
I guess if I'm getting good performance, then I should leave things alone,
but then again, maybe things could be *better* :mrgreen:
PostPosted: Mon Mar 19, 2012 10:05 pm
Million Club - 5 Plus
:mrgreen:
My experience is that you do have to at least try updated drivers... but first make sure you keep or are able to download the old ones that worked properly.
Ever since I upgraded my Catalyst drivers to version 12, my PC would crash to a black screen when viewing JPEGs with Windows Fax and Picture Viewer. The computer would either recover, or more recently, reboot as if someone hit the reset button. Downgrading to version 11.12 - which I'd saved - solved the problem.
PostPosted: Fri Jun 15, 2012 5:12 am
I don't recommend any. The reason why is basically when your computer vendor uses a component they get the driver from the component vendor and modify it. This happens alot with graphics cards drivers and they graphics cards manufacturers do have messages that drivers are sometime modified. So basically i look at the computer manufacturer drivers location and download from there when they do updates. Manufacturers typically don't update drivers for a machine that came out with 1 OS and another came out. In other words they tend to only support a machine with OS's that were on the machine when it came out. I typically will go to the components driver update site if I have upgraded the OS on that machine especially if the machine is out of warranty.
If you use one of those driver update applications it could cause problems because it doesn't have the computer manufacturer fixes.
PostPosted: Tue Jul 03, 2012 4:33 am
use driver magician it will find auto matic driver for your system and you can download them by 1 click
PostPosted: Mon Sep 29, 2014 3:30 am
Hi,
You can take the help of Driver Navigator Software to update your drivers. It detects and update the outdated driver that is creating issue in your system. This software is capable of resolving any sort of driver issue. You just need to follow the few simple steps and your work is done. When I used the software I came to know about its feature and specification which were really amazing. For more visit: http://www.softwaredownloadcentre.com/s ... igator.php
PostPosted: Tue Sep 30, 2014 7:50 am
Nothing like marketing to revive a zombie thread.
Currently Slimdriveris the MaximumPC staff favorite driver updater and it is free.
--I am not affiliated with MaximumPC, its publisher, distributor nor much else, except I have been a happy subscriber longer than some subscribers are old.--
