It is currently Sun Mar 29, 2015 1:36 am
 Post subject: Best Torrent Client?
PostPosted: Tue Aug 17, 2004 9:56 am
Wassup guys!
I`ve been using UPnP U-0.8.5 Fast Resume Client & Multilanguage because it proved to be fast, but I'm having problems because it's outdated to some trackers......
Can't decide which one to use some told me to try Azureus and Bit Tornado............. can some one tell me if theres another client fast enough, or which is the fastest?
Thanx in advance![/b]
PostPosted: Tue Aug 17, 2004 11:29 am
Contributing Writer
Contributing Writer
My favorite so far is ABC. Azureus would slow my system down too much, and Bit Tornado I haven't tried yet. I have it ready to install, but have yet to test it.
PostPosted: Tue Aug 17, 2004 2:24 pm
From what I've heard, Azureus is the best client.
I don't use BT though, so I haven't tested it out myself.
PostPosted: Tue Aug 17, 2004 2:31 pm
Team Member Top 100
Team Member Top 100
I've only used BT++.
PostPosted: Tue Aug 17, 2004 5:19 pm
ABC is a good client, and I currently use Azureus but it isnt as easy to use as ABC was.
Those are the only 2 clients I've used.
PostPosted: Wed Aug 18, 2004 12:52 am
Million Club
Million Club
I use TorrentStorm, myself. Nice interface and relatively easy control of all downloads and uploads/seeds. However I haven't tried any other torrent clients aside from the original version so my reccomendation is rather biased.
PostPosted: Sun Aug 29, 2004 9:36 pm
Azureus is definetly my favourite bit torrent client. It has the most options and is user friendly. Definetly recommended!
PostPosted: Mon Aug 30, 2004 11:50 am
off topic, but i think we need to add definetly into the auto-correction too. :D
PostPosted: Mon Aug 30, 2004 12:08 pm
Contributing Writer
Contributing Writer
Most definatly :wink:
PostPosted: Tue Aug 31, 2004 5:22 am
I my self use Bit Tornado.
I original had the "official BT client" switched to Bit Tornado and like that one much better
PostPosted: Tue Sep 14, 2004 7:38 pm
abc
PostPosted: Wed Sep 15, 2004 1:33 pm
If you like BitTornado, and that's the only client you've used, I would totally suggest Azureus. It has all (if not more) of the same functionality that BitTorrent does, and it improves on a lot of the things that they have in common, like more detailed tracker info, better download progress info, and some other things like that.
PostPosted: Wed Sep 15, 2004 3:27 pm
I've tried a few clients but I always come back to Bit Tornado. I just seems to work the fastest on my system. However, now I've curious about Azureus..does it have a searching option? ie. can you search for content like other P2P clients?
PostPosted: Wed Sep 15, 2004 6:18 pm
That would be a very difficult feature to implement using bittorrent.
The only way that I can think of would be to have the client interface with a website that has lists of torrents ... in which case, you may as well simply visit the website.
PostPosted: Thu Sep 16, 2004 3:25 am
That makes sense.
Thanks
