It is currently Tue Apr 28, 2015 12:55 pm
 Post subject: You can now SHIT CAN Windohs H8te Metro Forever!
PostPosted: Mon Feb 18, 2013 6:14 am
Here is a real quick fix for those who absolutely hate Metro in Windows 8, but are forced to use it. Ex7forW8 is a wrapper for the Windows 7 explorer, which means the Metro start screen is completely abolished and not even loaded. Absolutely no RAM or cycles are wasted on the Fisher-Price'like interface.
New Windows Explorer features like ribbon and file copying are preserved. The hack can be used on any Windohs version (W8, Server 2012 RTM or RP versions). This program does not modify system files or system protected registry entries and you can switch back to unaltered Windows 8 UI any time...as if and why! Yet, Windows 7 shell is enabled only to users which switched to it and other users can use Windows 8 shell without any problems.
It truly is a gem and works marvelously. I finally see the light at the end of this fuxed-up tunnel of vile tiles.
 Post subject: Re: You can now SHIT CAN Windohs H8te Metro Forever!
PostPosted: Thu Feb 21, 2013 12:38 pm
Thanks!!
I have been trying this out for a few hours so far and I like it.
If you despise that nasty #%^*@! metro UI as much as I do, then your going to like this!
