It is currently Mon Apr 20, 2015 7:06 pm
 Post subject: How do I allow others to access my files
PostPosted: Fri Aug 13, 2004 7:28 pm
Well, I locked my user account from access to others once b efore, and I forgot how to unlock it, Can someone tell me?
Looked or took away permissions??
PostPosted: Fri Aug 13, 2004 7:31 pm
Well, I go on my brothers file because I need to put some files on my account to his, and it says access denied.
PostPosted: Fri Aug 13, 2004 7:50 pm
Sounds like you just need to set permissions then.
Right click on the folder, select properties, and then deal with what's on the sharing tab.
PostPosted: Fri Aug 13, 2004 7:54 pm
ahh, thank you!
