It is currently Fri Mar 27, 2015 12:00 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3  Next
After installing Windows XP SP2...
Everything works fine 65%  65%  [ 33 ]
Most things work fine (just needed a few application updates) 25%  25%  [ 13 ]
Almost nothing works (all my apps needed updates) 0%  0%  [ 0 ]
Complete System Failure (Windows died and/or apps won't run and can't find updates to fix them) 10%  10%  [ 5 ]
Total votes : 51
 Post subject: The official SP2 after-effects thread
PostPosted: Wed Aug 11, 2004 7:03 am
In the lab!
In the lab!
Windows XP SP2 has finally been released!
Currently only the network installer (aka the business version) is available weighing in at 266MB! This version is designed to update all XP pro systems including home, pro, media center, tablet pc, etc and to be used in business environments by IT Professionals.
Soon there will be a consumer version put out on the windows update site as well as thru the automatic update service. I'd suggest home users just wait for this to become available as the network installer is very very very big!
You can read all about SP2 here:
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/winxpsp2.mspx
So please share both your successes and failures in this thread for others to read about.
PostPosted: Wed Aug 11, 2004 7:13 am
In the lab!
In the lab!
I'm still downloading the thing (I have dialup :cry: ) But soon as I do it's getting loaded onto every machine in my house.
I can't wait. I'm glad to see all the new features and security changes. I just hope they do make a differenece and help slow the tide of problems out there...
PostPosted: Wed Aug 11, 2004 7:58 am
Sailorman
Sailorman
No problems here yet Dex. Two days now. Even third party themes work since i patched the .dll
 Post subject: Re: The official SP2 after-effects thread
PostPosted: Wed Aug 11, 2004 8:26 am
just minor issues, like having to open some ports to let some applications work.
 Post subject: After installing SP2
PostPosted: Wed Aug 11, 2004 6:30 pm
I haven't had any problems. I put it on my test machine and my personal laptop. I have about 20 machines at work running xp and I hope to have it all scoped out by the 16th when I heard it goes live on AU.
PostPosted: Thu Aug 12, 2004 1:52 pm
Team Member Top 100
Team Member Top 100
Maybe I did something wrong....but it just crashed my notebook. Ran the update, computer restarted, it would show the "windows XP" loading screen and then flash the background....before restarting again. I let it do this for about 1/2 hour. Now trying to restore from the windows cd.....<prays>
PostPosted: Thu Aug 12, 2004 2:50 pm
everything's been fine for me ... only annoyances ive had is that it tries to require you to have some sort of antivirus, but u can turn that off. also, the popup blocker notification when it blocks a pop-up is kinda annoying, that can be turned off too tho.
 Post subject: *brag post*
PostPosted: Thu Aug 12, 2004 6:28 pm
team psycho or sumthin
took me all of 9minutes to get the 266mb file, only had one problem ant that was with a IE based chat program.....a simple desktop shortcut took care of it.
PostPosted: Thu Aug 12, 2004 8:25 pm
I downloaded the file in just over 9 minutes. Installed pretty fast(3.6Ghz, 1gig HyperX, Raptor RAID 0). I haven't had any problems with programs or anything. Turned off the "no anti-virus program warning". All is well so far.
PostPosted: Thu Aug 12, 2004 8:27 pm
Team Member Top 100
Team Member Top 100
Yup, completely boinked my Alienware notebook. Had to reinstall windows. SP2 worked fine the second time though.
Now I got to start reloading everything. Its going to be a long night.
Also, Alienware's "Master Disk" with the drivers is a JOKE. I had to download two drivers (one for ATI, the other for the PCMCIA) and I still can't get my Network driver to install. Gonna have to make a phone call....
 Post subject: Driver update
PostPosted: Fri Aug 13, 2004 5:36 am
Team Member Top 100
Team Member Top 100
After installing SP2, I kept getting EL99X errors in my System Event Log referring to "DMA download engine failure." My network connectivity would also drop, and the system would freeze for a few seconds. It culminated in a BSOD which Microsoft's error reporting followup suggested might be caused by a device driver.
I downloaded the latest 3Com drivers for my network cards (they're both 3CR990SVR97 types) on another machine, then updated the drivers.
All has been well since doing that (other than opening a few ports for my apps.
PostPosted: Fri Aug 13, 2004 7:57 pm
Programs that may behave differently in Windows XP Service Pack 2
http://support.microsoft.com/default.as ... ndowsxpsp2
Dave
PostPosted: Sat Aug 14, 2004 1:29 pm
In the lab!
In the lab!
finally got sp2 installed... everything appears to be working but I guess I'll find out in time.
 Post subject: XP SP2
PostPosted: Sun Aug 15, 2004 11:05 pm
installed it on two machines, and so far both are working fine.
PostPosted: Tue Aug 17, 2004 2:26 pm
I thought this might be helpful to you guys.
It's a complete list of bugs fixed by SP2
PostPosted: Tue Aug 17, 2004 7:43 pm
Sailorman
Sailorman
I started to read that page and JEEZ! :shock: I saved it to read later.
PostPosted: Wed Aug 18, 2004 2:41 am
The Logik! Bot
The Logik! Bot
Tastes great!
Less filling!
:lol:
PostPosted: Wed Aug 18, 2004 4:35 pm
Installed SP2 last night thanks to a copy of the file thoughtfully provided by a friend with bradband.
Works good. . .it seems to have fixed the intermittent error I was getting with the display driver for my 6800 ultra, which would crash or reboot the system sometimes. Otherwise the only thing I noticed was Style XP needed an update. Even after the update tho, the window colors in some of the styles are different. There are other graphical anomalies like the menus in the tree pane of PD Explorer 5 look a little weird as well. Otherwise the system is stable, and seems a little faster than it was.
I liked how the system auto recognized McAfee AV and FW and didn't bug me about those options. Like others have said, other "features" of the new "secure" Windows are easily turned off (I didn't like how OE decided to stop downloading images in my E-mails, for instance). The new Windows Update has the same functionality of the old one, but looks cooler. In spite of the dire warning against it, stuff seems to download faster as well.
I'm just glad it didn't bork my machine. I haven't backed up my files in a while. . .
PostPosted: Wed Aug 18, 2004 6:36 pm
The Logik! Bot
The Logik! Bot
Spectrum wrote:
I didn't like how OE decided to stop downloading images in my E-mails, for instance.
I love this feature. No more inadvertently validating SPAM via your email address because of some invisible GIF that gets downloaded...
PostPosted: Wed Aug 18, 2004 7:38 pm
Sailorman
Sailorman
I second that.
