It is currently Tue Jan 27, 2015 9:07 am
 Post subject: UxTheme under Windows XP SP2
PostPosted: Tue Aug 10, 2004 11:54 am
anyone got it to work can provide some instructions? i lost it after installing SP2 and can no longer remember how i did it the first time.
also, which .dll patcher works with the final SP2? i got a 1.5.1 one.
 Post subject: Re: UxTheme under Windows XP SP2
PostPosted: Wed Aug 11, 2004 7:50 am
Sailorman
Sailorman
http://www.tcmagazine.info/modules.php? ... load&cid=6
You must have "show hidden files and folders" enabled in folder options.
You must have "hide protected operating system files" unchecked in folder options.
YOU MUST start in safe mode, and find the uxtheme.dll in the windows\system32 folder and in the windows\system32\dllcache folder. Rename the .dll found in both of these folders to uxtheme.bak or uxtheme.old. Paste the new .dll in both folders and restart.
My themes all work fine with XPSP2.
PostPosted: Wed Aug 11, 2004 7:59 am
Nightcrawler wrote:
http://www.tcmagazine.info/modules.php?op=modload&name=Downloads&file=index&req=viewdownload&cid=6
wow, such a long step instead of just clicking a .exe file. i'll work on that when i get time. thx.
