It is currently Sun Apr 19, 2015 5:30 am
 Post subject: Does ZoneAlarm Pro 5.1.011 allow chkdsk /f ?
PostPosted: Sun Aug 08, 2004 8:16 pm
Does ZoneAlarm Pro 5.1.011 allow chkdsk /f ? Previous 5.x didn't allow chkdsk /f .
PostPosted: Sun Aug 08, 2004 10:17 pm
Yes!!! That problem has been fixed. If you also run Diskeeper8Pro, you will have to go into services.msc and set it to manual. Unfortunately I installed Diskeeper8Pro shortly after installing ZA 5.xx and couldn't figure out why checkdisk would not run for a couple weeks. :roll: It does work with ZA 5.1.011.000. SP2 2180 recognizes it and no conflicts there either. SP2 installs with the Windows Firewall off if you have that version of ZA. :D
PostPosted: Sun Aug 08, 2004 10:21 pm
From the release history page.
New and improved features in ZoneAlarm Pro version 5.1.011
Added Microsoft Security Center support
Added support for Microsoft SP2
Added anti-phishing protection for PayPal users
Fixed Internet Explorer browsing issues
Fixed IIS FTP Server issues
Fixed Visual Studio2002/2003 with IIS issues
Fixed AOL Browser issues
Fixed check for update issues (proxy configuration detection)
Fixed issues with checkdisk
Fixed more system stability issues
Routine maintenance items
New and improved features in ZoneAlarm Pro version 5.0.590.043
Fixed Norton AV e-mail scanning issue
Fixed issue with SSH timout
Fixed installation issue with McAfee Security Center
Fixed system stability issues
PostPosted: Mon Aug 09, 2004 11:54 pm
Hi fishnet,
You responded to a post I made in another ZA thread. Glad to hear it wasn't the cause of your problem.
Also very nice to know ZA solved the two issues giving my comp fits. I always liked th eprgram, but it had to go when everything went tits up.
I'm happy with Kerio for now, but may tempt the fates and give Za another run. :)
PostPosted: Tue Aug 10, 2004 5:14 am
I do use DK8pro. Why do I have to set it to manual?
PostPosted: Tue Aug 10, 2004 4:14 pm
On my machine if I leave diskeeper in auto, I can't run checkdisk. :roll: I get that: Disk in use. Cannot access disk error message.
