It is currently Sun Mar 29, 2015 5:32 am
 Post subject: Best version of Windows XP?
PostPosted: Mon Jul 05, 2004 4:51 pm
Can someone tell me what the overall best and most reliable version of Windows XP? I'm trying to avoid opinions and get factual answers if possible.
PostPosted: Mon Jul 05, 2004 5:03 pm
Win XP
home or pro is your option. WinXP is the best windows OS
get SP1 with all the critical updates
it is my opinion and fact
PostPosted: Mon Jul 05, 2004 5:42 pm
Home and Pro are both reliable.
Pro would be better if you have a LAN (or plan on going to one soon).
Pro also has the ability to disable simple file sharing (which I dont think Home will allow).
Pro is obviously better if you consider yourself a power user.
Otherwise Home will do just fine.
PostPosted: Mon Jul 05, 2004 6:02 pm
Windows XP Home and Pro are the same except for some key advanced features that Pro does such as Remote Access, Manageability, Security to name a few that you can read about here:
http://www.microsoft.com/windowsxp/home ... sing2.mspx
You can also read this write up that Logik did that better explains what the difference between the two are:
http://www.ultratech-llc.com/KB/?File=/windows.txt
Pro also supports Two Processors compared to Home only supporting one.
I personally use XP Pro.
Dave
PostPosted: Mon Jul 05, 2004 6:13 pm
go with pro. more options
PostPosted: Mon Jul 05, 2004 6:29 pm
I vote pro, It gives you much more flexibility later on, if you say decide to have your own domain at home (as I do now) or just need more advanced networking options in general.
not that much more expensive and much more advance networking options.
PostPosted: Mon Jul 05, 2004 6:37 pm
Thanks to you all for the advice!
