It is currently Tue Mar 31, 2015 9:38 pm
 Post subject: Format
PostPosted: Tue Aug 03, 2004 4:32 am
Good Morning
Our computer is partioned into 3 drives (C) our main one then (D)&(E). D drive has so much junk instead of deleting everything I am going to just Format the Drive. Will formating remove the things in the regeristy :?:
Thank You
Ed
PostPosted: Tue Aug 03, 2004 5:06 am
INFINITE vCORE
INFINITE vCORE
Nope. It will leave the registry as is...
But it will break any shortcuts or registry entries pointing to any programs or data installed on D:
PostPosted: Tue Aug 03, 2004 7:01 am
formating with just wipe everything from a specific partition, including program files and windows files, provided that they are on that partition.
If you want to turn this into one big disk again, you'll want to remove all the partitions and just recreate one big one.
PostPosted: Tue Aug 03, 2004 7:44 am
If you want to clean the registry the best way would be to uninstall the stuff on D through windows...
