It is currently Tue May 21, 2013 4:52 pm
 Post subject: Clean Install Win8 from Upgrade Media: Step-by-Step
PostPosted: Wed Nov 14, 2012 8:06 am
Here is your hand holding to turn that $40 win8ate upgrade into a full fledged clean install
Step 1: Use the Upgrade Assistant to qualify the PC and pay the $40 (US)
Step 2: When the "Install Windows 8" message appears, select "Install by creating media" to create a bootable USB flash drive or an .iso (a disk image) file.
Step 3: Wait for the Assistant to download the Windows 8 Pro installation package and create the bootable media or .iso file. The flash drive must be have 3GB or more of free space available.
Step 4: Burn the .iso file, if that's the path you chose, to a blank DVD.
Step 5: Use that USB drive or DVD to boot the PC.
Step 6: When you get to the screen in Setup that asks, "Which type of installation do you want?' choose "Custom."
Step 7: Select a disk partition for the OS in the next screen. At this point, you can create a new partition if there's enough space available, or reformat the drive.
Step 8: Continue with the installation of Windows 8 Pro.
How to reinstall Windows 8
You have a couple options:
Option 1
If you would like to reinstall Win8, which means removing apps and personal files and settings, you can use reset and refresh. This is equivalent to a clean install. To do it, do the following:
1: Press Windows key + i on your keyboard to show the Charms bar (If you are using a touchscreen: Touch the right edge of your screen and swipe your finger to the left)
2: Click Settings
3: Click Change PC settings
4: Click General in the left column
5: Under Remove everything and reinstall Windows, click Get started
6: Then follow the instructions that will be provided on the screen to reinstall Windows on your PC.
Option 2
If you create a installation DVD or Bootable thumbdrive, you can use that to reinstall Windows. First, you will need to reinstall the qualifying license, then start the upgrade again to Win8. Qualifying license means you will either need to reinstall Windows XP, Vista or Win7.
Option 3
A workaround for this situation is to create a system image of Win8 just after you have upgraded. So if your drive does crash, you can simply restore the image on a new hard disk or restore the image on the same drive if you just want to reinstall Win8. See the following for instructions about how to create a system image of your Windows 8 installation. It references Win7, but the exact principles apply to Win8.
