It is currently Sun Jan 25, 2015 4:34 pm
 Post subject: System Resource
PostPosted: Sun Aug 01, 2004 4:42 am
Where is system resource % located ? I would like to see what % my computer is running at.
Thank You
Ed
PostPosted: Sun Aug 01, 2004 7:31 am
Right click the start menu, select Task Manager, then go to the performance tab.
This is for Windows XP or 2000.
I cant recall the way to do it in 98, I think you had to go into system tools or something like that and open up a program.
 Post subject: system resource
PostPosted: Sun Aug 01, 2004 11:51 am
Thank You SomeGuy
Ed
PostPosted: Sun Aug 01, 2004 12:11 pm
If memory serves, in 95, 98, 98SE you had to open My Computer, and go help/about
