It is currently Thu Mar 26, 2015 6:46 pm
 Post subject: File won't delete!!
PostPosted: Fri Jul 30, 2004 1:16 pm
I have an .exe file on the WinXP desktiop that won't delete!! It says it being used (seemingly by "system idle process" because its CPU usage is at 99%, and I can't terminate that process.) How can I forcibly delete this file? I've tried recovery console and it won't run the delete command.
BTW: This file is an old DOS game file that's actually .prj that I renamed to .exe. So it's a totally useless file. But I can't delete it! :(
PostPosted: Fri Jul 30, 2004 1:18 pm
Contributing Writer
Contributing Writer
If you can't do it through a command prompt, reboot in safe mode and delete the bugger.
PostPosted: Fri Jul 30, 2004 1:19 pm
How do I get safe mode?
PostPosted: Fri Jul 30, 2004 1:21 pm
Contributing Writer
Contributing Writer
When rebooting, hold down F8 and you should be brought to a prompt asking if you wish to boot into safe mode.
PostPosted: Fri Jul 30, 2004 1:32 pm
Finally took care of that mofo! Thanks! :wink:
PostPosted: Fri Jul 30, 2004 1:36 pm
Contributing Writer
Contributing Writer
Welcome ts, glad to hear it :)
