It is currently Thu Mar 05, 2015 10:08 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Tell me everything you know about WinXP SP2 RC2
PostPosted: Wed Jul 28, 2004 11:43 am
1) Where to download it?
2) How to install it?
3) What to do to prepare my XP Home notebook which has Norton AV installed?
4) What can possibly be different between RC2 and the actual released version?
5) Will Windows Updates work with it for new critical updates if I'm using the RC, or will it pester me forever to install the final version?
THANKS!
PostPosted: Wed Jul 28, 2004 1:27 pm
Astro lube 2 the MAX!
If you have SP2 RC1 installed, windowsupdate should have it. Otherwise Microsoft download section has it. If not, search function is there for your help.
Make sure all programs aren't running, Use Task Manager to close out any unecessary programs. Disable any antivirus you might be running. Make sure you do a system restore point. Either Windowsupdate will run it automatically, or if you downloaded it, have to run the setup file.
Rightclick the norton icon on your taskbar, and disable. Or just Taskmanager and endtask the norton proggie.
LOTS. By installing this beta pack, you know this isn't the final product, so be aware of any bugs.
Windows update will work and install new critical stuff they add. As long as your using a legit cd-key, you will gain access to Windowsupdate. Otherwise if your an unlucky individual with a banned key, you'll have to call microsoft for a new key if your using a corporate copy.
PostPosted: Thu Jul 29, 2004 5:53 am
Woot. Thx for the 411. I did scour MS's website for the RC2 download but all I cam up with was this approx. 250MB network install package. Can I use that?
PostPosted: Thu Jul 29, 2004 6:57 am
Thats what I used :) Just download it and run the .exe
 Post subject: What is RC1 & RC2?
PostPosted: Fri Jul 30, 2004 5:28 am
I have Windows XP Pro Version 2002 with SP2 installed.
My system indicates: Service Pack2, v.2149
No reference to RC1 or 2??? :roll:
 Post subject: Re: What is RC1 & RC2?
PostPosted: Mon Aug 02, 2004 8:08 am
I believe that is how it is id'ed.
PostPosted: Mon Aug 02, 2004 8:14 am
notice the v.2149 (.2 beta ...i.e. RC2)
 Post subject: For those who have installed Windows XP SP2
PostPosted: Mon Aug 02, 2004 8:34 am
I've heard that the new service pack has a 'feature' of not shutting down until it has finished downloading updates. Can anyone verify that?
- Jacob
PostPosted: Mon Aug 02, 2004 6:04 pm
That was the RC 1 release. I used RC2 for a couple months without any problems other than the Security Center not recognizing Zone Alarm or NAV. I disabled it. I'm a pretty light weight user though.
To try the single user version you have to go to the beta download site and install the Beta Update software first. Then you can download RC2. For me the installation was problem free. The final release is so close, I'm not sure you want to download a beta you will remove in a few weeks. Here is the link for the Beta Update download.
Update Link
[url]
http://v5.windowsupdate.microsoft.com/v ... ankspage=6
[/url]
This link will tell you all you want to know and more. :D
http://www.scotsnewsletter.com/59.htm#winreport1
PostPosted: Tue Aug 03, 2004 3:03 pm
question:
i'm running build 2149, how do i update to the latest? Windows Update does not show anything.
PostPosted: Tue Aug 03, 2004 6:13 pm
i think that is the latest....
PostPosted: Tue Aug 03, 2004 6:19 pm
i'm hearing 216x and 218x already...
can't recall the last number atm.
PostPosted: Tue Aug 03, 2004 8:24 pm
AFAIK .2149 is the most recently Public Beta I believe you are correct that builds .216x and .218x may indeed be out there but they are only supposed to be available to specific members of a specific Beta Test group right now.
PostPosted: Wed Aug 04, 2004 2:18 pm
I just want to thank everyone for the continued updates & info!
PostPosted: Thu Aug 05, 2004 4:49 pm
Latest news for those of you who are watching the SP2 release timeline. Looks like we'll be seeing the final version very soon.
Here's a smidge of speculation as well as some more official news.
As always, Google's news bot is a nice way to get the lastest information.
Definitely going to be interesting to see how well Microsoft has done (at least, for those of us who haven't had the opportunity to check out the release candidates).
Jacob
PostPosted: Fri Aug 06, 2004 1:01 pm
[quote="ComputerSlayer"]Latest news for those of you who are watching the SP2 release timeline. Looks like we'll be seeing the final version very soon.
The final version is out to beta testers. You can d/l it now. Goto war2search.net for the link. It will be available through windows update in a few weeks.[/url]
PostPosted: Fri Aug 06, 2004 4:44 pm
according to computerworld mag, ms released it to manufacturing today
PostPosted: Fri Aug 06, 2004 4:46 pm
http://www.computerworld.com/softwareto ... 01,00.html
PostPosted: Sun Aug 08, 2004 10:25 pm
It's already out if you know where to look. :D
