It is currently Mon May 20, 2013 9:12 am
 Post subject: Grab control of your pagefile with CleanMem
PostPosted: Fri Sep 21, 2012 4:43 am
If you need a contemporary memory page file solution, this is it. CleanMem keeps memory use in check on the system without the memory being pushed to the page file. This in turn keeps the system running smoother. The latest and greatest CleanMem 2.4.3 works buy calling a Windows API. It doesn't change the working set of a processes. It simply asks Windows to do all the work. So Windows does the trimming, the moving and manages everything. This is why there is never any crashes of programs and any performance hit to the system. To put it short CleanMem doesn't work against the Windows memory manager, it works with it.
