It is currently Sat Jan 31, 2015 8:28 am
 Post subject: ClearType option under Effects
PostPosted: Fri Jul 23, 2004 8:11 am
the option under Effects in the Display properties for Windows XP. i was wondering if this thing is a resource hog or not, as i remember reading somewhere about actually turning the font smoothing option completely off.
i kinda like the way it makes text look.
PostPosted: Fri Jul 23, 2004 8:14 am
I turned all that junk off on mine (shaded menus, cleartype fonts, etc) and I didnt really notice much difference in performance on mine. So I turned it all back on since I liked the way it looked better.
I have an AMD XP @1.73GHz adn 512MB RAM and a GF2 ultra...
PostPosted: Tue Jul 27, 2004 6:37 pm
i dont notice a difference either though maybe the computer does. i turn the clear type on since i like the way the text looks too. i think it looks better and the text for me is more readable and more clear.
 Post subject: Re: ClearType option under Effects
PostPosted: Wed Jul 28, 2004 9:57 am
I think it's a form of Anti-Aliasing, so I'm sure it requires *some* processing time, but I don't think it's much. It's one of the few things I have enabled. Under the 'Performance' tab, I have most things unchecked.
The fading menu's seem to require the most power that I've noticed.
PostPosted: Wed Jul 28, 2004 10:30 am
i think it is just the way to "smooth the type"
i have it on...and things look much better on my LCD (1280x1024)
also, i didnt notice any resources used up
PostPosted: Sat Jul 31, 2004 1:55 am
Chief Surgeon
Chief Surgeon
In general, if you have over a 1GHz Processor, 256Mb Memory, and a 32Mb Graphics card, you won't see much difference in performance by killing off the eye candy.
If you have slower than that, oh yeah. Big difference. :)
SC64
