It is currently Mon Apr 20, 2015 9:53 pm
 Post subject: Windows XP boot optimizer
PostPosted: Tue Jul 27, 2004 12:00 pm
At some point my install of XP Pro started to boot extremely slow, right after I login. I'd like to find out which program/driver is causing problem. Is there some kind of boot monitoring utility for this? I remember reading something somwhere about Boot monitoring/optimization utilities. Can someone point me in the right direction?
BTW, inspecting Event Viewer didn't reveal much, and I also disabled extra services...
PostPosted: Tue Jul 27, 2004 3:06 pm
Here you go
http://www.softpedia.com/public/cat/12/2/12-2-1.shtml
I don't believe you can monitor you boot process with this software (Bootvis), but it is a boot optimizer. I would also recommend deleting everything in your prefetch folder and jumping into msconfig and getting rid of any extra startup items.
hope this helps
PostPosted: Tue Jul 27, 2004 4:20 pm
bootvis
avaliable on google
PostPosted: Tue Jul 27, 2004 5:37 pm
look up bigpa :)
PostPosted: Sat Jul 31, 2004 7:20 am
Thanks for your help! :)
