It is currently Sun Jan 25, 2015 1:54 pm
 Post subject: speed up Windows Explorer file sorting?
PostPosted: Tue May 08, 2012 10:14 am
When uploading image files, I sometimes need to reorder them so the newest, oldest, largest, etc are at the top.
It's been taking up to 3 minutes for Windows (7 64 bit) to reorder them so I can find what I'm looking for.
Is there a way to speed this process up?
 Post subject: Re: speed up Windows Explorer file sorting?
PostPosted: Tue May 08, 2012 12:05 pm
If you have a ton of images in one folder, it could be building the thumbnails of images you didn't look at. Among other things that I'm not aware of. I would say since this is a file IO thing, the only way to speed it up is to do your usual HDD maintenance or get an SSD.
PostPosted: Wed May 09, 2012 7:15 pm
Yes, there are thousands of pic files.
Thanks for the reply.
