It is currently Sun May 03, 2015 11:23 pm
 Post subject: suggestions for WHS 2011 user accounts
PostPosted: Tue Apr 10, 2012 9:59 pm
I've finally gotten my server set up (again, after a system disk crash earlier this year--luckily it was just the OS drive).
Anyway, I'm re-doing the user accounts. What do most people suggest for user accounts? I don't use the Remote Web Access system. I mainly remote into the system via Remote Desktop from my desktop PC or laptop (from within my home network).
Should I create a Standard user account for this, or is using the Administrator account suitable (When I remote in, it is mainly to administer the system: install updates, run AV scans, install server applications, etc).
Suggestions? I'm mainly concerned with security.
Secondly, if you log off, do services, such as my AV app, continue running? (I'm using ESET Nod32 AntiVirus 5.0)
 Post subject: Re: suggestions for WHS 2011 user accounts
PostPosted: Fri Apr 13, 2012 2:42 pm
You answered it yourself. Make an account for you and move on. If you want everyone to have admin rights with the ability to fuck it up, then add them all. Add me while you're at it.
You use remote access to remotely access it. That's Server 2008 terminology.
