It is currently Tue Apr 28, 2015 11:56 am
 Post subject: Sleep Tuning in Win7?
PostPosted: Fri Apr 20, 2012 9:58 pm
I want to set my Win7 x64 Home Ultimate rig differently from the standard power management options. I want more control over the sleep settings, being able to define exactly how much time must pass before it goes to sleep (e.g. 12 hours; 1 hour, 48 minutes, etc.). Do you know of any trustworthy programs that offer this flexibility?
 Post subject: Re: Sleep Tuning in Win7?
PostPosted: Sat Apr 21, 2012 4:07 pm
Windows Search bar > "Power Options" > "Create a power plan" on the left or "Change plan settings" for one of the default plans.
PostPosted: Sat Apr 21, 2012 9:27 pm
There's also some things in command line you can do. I don't know if Windows 7 actually does obey them since I have this standard user/admin shenanigan thing.
PostPosted: Fri May 25, 2012 10:51 am
I'm curious, what do you know that the rest of us don't...why do you need to be so prescriptive?
