It is currently Thu May 23, 2013 8:27 am
 Post subject: data transfer via usb(cables.to.go) software
PostPosted: Mon Feb 13, 2012 3:08 pm
just want to move data via usb cables.to.go device, included software is no.go
any advice appreciated.
 Post subject: Re: data transfer via usb(cables.to.go) software
PostPosted: Mon Feb 13, 2012 7:04 pm
wow...that couldn't be any more vague....even if you did try.
PostPosted: Thu Feb 23, 2012 10:41 am
let me xplain'
i have 2 computers
i want to move data between them using a usb cable
what part of that is confusing to you?
im using a cables.to.go usb cable, if your are not familiar with this product, please go elsewhere.
im looking for software that will enable me to move data between 2 computers using this cable.
there was no reason to be rude
PostPosted: Fri Feb 24, 2012 1:56 pm
So first things first...perhaps you need a look at this...
viewtopic.php?f=6&t=113190
Now no one is going to tell you how to configure it and make the software work, because that's what the instructions is for.
Unless of course you want to add some specifics about your situation.
PostPosted: Sat Feb 25, 2012 10:10 am
im using
winxp.32 and win7.64
the included software is not useful. more for moving installation files from xp >> win7
im looking for other software, that can move files between a laptop to comp.
xp to win7 or win7 to win7, i skipped vista.
i can use my network, but im looking for a way to use the usb data cable, especially when im not home or at a friends.
btw, i did run a search on site before i posted, i just want to move files across platforms
ed
