It is currently Fri May 24, 2013 5:25 pm
 Post subject: Why can't Win7 remember window size & position like XP??
PostPosted: Sat Jan 07, 2012 10:57 am
What is the rational (if there actually is any) of not allowing one to save window size & position (other than the last window opened)? :confused:
Without using a 3rd party program (which seems to be the norm with Win7) has someone found a way to allow saving resized windows other than the last window opened??
 Post subject: Re: Why can't Win7 remember window size & position like XP??
PostPosted: Sat Jan 07, 2012 3:14 pm
Possible hotfix?
http://support.microsoft.com/kb/979560
Otherwise it's a built-in code error without a third-party fix.
http://social.technet.microsoft.com/For ... 81d106a19b
PostPosted: Sun Jan 08, 2012 3:21 am
Yes, since I wrote this, I did see those. Not really a fix.
Looks like another new unwanted feature needs to be removed to restore a long time standard feature that now is broke.
PostPosted: Sun Jan 08, 2012 11:09 am
Well, if the number of 7 users who complain about this issue are small, and the other 99% don't give a crap (=most non-power users?), then M$ won't bother to "fix" what isn't "broken".
I didn't know about this issue before your post because I'm still using XP. But when or if? I use 7 when support ends for XP in 2014, I already know this will be a major-league source of irritation for me.
Maybe it's because 7 no longer has a "Classic View"? I'll hate that, too, I know already.
PostPosted: Mon Jan 09, 2012 7:07 am
Judging by the huge number of results after doing a search on the subject, it surely isn't a "small" issue! Just as the loss of the classic start menu is even a larger problem. :evil:
PostPosted: Tue Jan 10, 2012 11:40 pm
I used this back in XP/Vista and it still works in 7.
Open up the window that needs to be changed/saved and hold CTRL and click to close out the window.
Edit: Also, I loved this utility when I had XP. http://www.southbaypc.com/autosizer/
Edit2: Why do people like classic view? I just type in what I want and it search it for me.
PostPosted: Wed Jan 11, 2012 3:35 am
How does one save an Explorer window???
There is no "save" under File.
PostPosted: Wed Jan 11, 2012 3:19 pm
Hold CTRL and close it out.
PostPosted: Thu Jan 12, 2012 3:38 am
It only seemed to remember positioning the window to the top of the screen (it was somewhere around the middle before). It's still a 800x600 default window.
I did it a couple of times.
I only have the default M$ supplied driver installed video driver installed (ATI). Would that matter?
PostPosted: Mon Jan 16, 2012 10:43 pm
http://sourceforge.net/projects/classicshell/ :P
PostPosted: Tue Jan 17, 2012 6:40 am
I considered that, but it has to run another process/service for it to work. :(
There's no shortage of services/processes running with each new M$ O/S. :evil:
