It is currently Wed May 22, 2013 9:17 pm
 Post subject: Why I am receiving message "Connecting through WAM miniport?
PostPosted: Sat Dec 24, 2011 12:10 pm
Hello experts !
Since a few weeks ago, while I am working normally in my p.c., I receive the following message: "Connecting through WAM miniport (PPPOE) Error 651: the modem (or other connecting device) has reported an error." and then a smaller square box saying "Connecting to broadband connection".
Everything works fine, I don't get disconnected at any time, I work and continue working with Internet, Windows Live Mail, etc. as smoothly as it should be. But I wonder why do those message appears from time to time ?
How might I avoid that those tiny screens appear in my screen ?
Thanks in advance for your answers and suggestions.
Best greetings from New York,
Antonio Machado.
 Post subject: Re: Why I am receiving message "Connecting through WAM minip
PostPosted: Sat Dec 24, 2011 12:38 pm
It's pretty hard to slip new tech by me, so I'm just going to assume that we're talking about a WAN miniport here.
Sounds like your modem is trying to dial up a connection before the system defaults to a broadband connection. Try this...
Start ---> Control Panel ---> Internet Options ---> Connections Tab ---> check the box labeled "Never dial a connection" ---> Apply ---> OK ---> reboot.
That should do it. If not, hit us back. Good Luck/Happy Holidays!
PostPosted: Sat Dec 24, 2011 1:13 pm
Thank you vig1lant3, I just did it as you suggested and I think that will make it.
Thanks a lot for dedicating time to help me.
My best greetings from New York, Antonio Machado.
