It is currently Sun Mar 01, 2015 8:58 am
 Post subject: How do you keep Windows 7 Tidy?
PostPosted: Thu Dec 15, 2011 8:38 am
I'm completely new to Windows 7.
On my old Win XP machine I used WinUtilities for registry cleaning, file cleanup, etc.
Any software you can recommend?
I prefer freeware because in the past I have tried payware for about a year but then wouldn't renew my subscription when it expired.
 Post subject: Re: How do you keep Windows 7 Tidy?
PostPosted: Thu Dec 15, 2011 9:03 pm
Try Ccleaner on for size. Good at keeping internet cache under control, and the registry cleaner is one of the best for a free solution.
PostPosted: Fri Dec 23, 2011 6:16 pm
I second the motion!, been using it for years and never had an issue with it!
PostPosted: Fri Dec 30, 2011 9:55 pm
And I 3rd the motion! In addition, use CCEnhancer for even greater scrubbing and cleansing power.
A superior alternative to CCleaner with heightened functionality, look to System Ninja. Ninja is a lightweight program designed to clean your computer of unwanted junk, constantly slowing your entire system down. Like CCleaner it is a fast and powerful file cleaner, but it provides features far beyond such as Startup Manager, Process Manager, plus several useful tools such as CCEnhancer, FileAnalyzr and MalRunDestroyer.
