It is currently Sun Apr 19, 2015 9:46 am
 Post subject: Antivirus uninstalling problem?
PostPosted: Thu Oct 13, 2011 8:09 am
I use Win7 Ultimate edtion,there is only one account and that's d admin account.....my antivirus program(AVIRA antivirus),,i used this program on my PC for about 4-5 months.i uninstalled this program once but something went wrong in uninstalling,,from then this prog. is not listed in ''Add or remove programs'' but the folder where i hav installed this prog. on is still present in C:\Program files....When i try to delete the folder manually i get the error ''requires admin permission''...pls. help me uninstalling this antivirus program
 Post subject: Re: Antivirus uninstalling problem?
PostPosted: Thu Oct 13, 2011 11:54 am
It is uninstalled. If the program is still running on startup, try Revo Uninstaller. It is really good at uninstalling tough-to-uninstall programs. Do you have another AV program running currently?
PostPosted: Fri Oct 21, 2011 9:14 am
I know this is an older post, but just in case you didn't find this yet, download and run the Avira Registry Cleaner Tool. It takes it awhile to delete all the registry keys, but be patient, and you'll "git er done", hopefully :wink:
edited: changed to correct link.
PostPosted: Sun Oct 23, 2011 8:15 pm
I also encountered that one. What I did was I restarted the pc and try uninstalling again the program.And that's it. it worked!
Chudson
Link Removed
Users browsing this forum: Stam and 4 guests
