It is currently Fri Feb 27, 2015 9:36 pm
 Post subject: Business Security
PostPosted: Fri Oct 07, 2011 9:54 am
Hi,
I'm doing a bit of research for my company about upgrading our software solutions.
Security is of prime concern. I'm looking for information about laptop encryption/remote wiping, and I'm looking into cloud storage. I'd like to have a virtual private network (basically I want all the information stored offsite or online but I want to access it like a normal file system in a network drive).
Does anyone know where to start?
Thanks!
 Post subject: Re: Business Security
PostPosted: Fri Oct 07, 2011 7:37 pm
For encryption, do Truecrypt. If you use the "hidden" method, the existence of the data can be denied, and it can do AES+blowfish. I don't know any remote wipers, though.
PostPosted: Fri Jan 06, 2012 9:04 am
You can also use TrueCrypt on cloud by extract the contents onto your cloud storage. I used it for my Dropbox.
