It is currently Fri May 24, 2013 5:04 pm
 Post subject: Volume Leveling Software
PostPosted: Sat Aug 20, 2011 11:00 pm
Does anyone know of a way to level off/boost the audio coming out of a system all to the same level? Basically, what I want is if I set the system volume to 100, then every program plays at 100, instead of having its own individual setting that winds up being less that max. I know that Windows 7 has volume equalization, but that only makes everything that is playing as loud as the currently loudest sound, and doesn't make things level over time.
 Post subject: Re: Volume Leveling Software
PostPosted: Sun Aug 28, 2011 9:49 pm
So... guess these forums are dying out.
PostPosted: Wed Aug 31, 2011 8:16 pm
no, it just cant be done, there is no "automatic" mixer.
PostPosted: Wed Aug 31, 2011 8:49 pm
I just can't see how you can determine what the current volume level of the file is and then adjust accordingly on the fly without some sort of info in a header (for a lack of terms) in the file...
PostPosted: Sat Sep 03, 2011 8:32 pm
I haven't done any serious testing but Smart Volume from Creative works. I never get the extremely loud Youtube video or something of that nature to blow out your ears.
It's listed at the bottom here and yeah you probably need to buy a soundcard.
