It is currently Fri May 24, 2013 12:11 am
 Post subject: Vista..oh no!
PostPosted: Sat Aug 27, 2011 4:00 am
I have a friends HP Pavilion that was full of everything bad imaginable....his antivirus ran out. I used the Restore disks from the factory to reinstall the OS and it did. It was SP1 version, so I loaded SP2, now I have a blue screen telling me not to touch the pc until system prep is done....that was last night. How do you stop this pieces of crap from running? I can see and use the programs menu but anything I open goes behind the blue screen and I can't use the program...msconfig in this case to shut off the stupid system prep program!
Any ideas to kill this program? I can't even get into Safe Mode, the same message pops up that system prep cannot run in Safe Mode and restarts the computer. BAH!!
PS, this pc is for a home bound friend that uses it for everything...banking buying food ectra.
 Post subject: Re: Vista..oh no!
PostPosted: Sat Aug 27, 2011 8:03 am
I would nuke the drive and start again. Do you have a spare copy of 7 you can give him? If not, go install Vista SP! and try again.
 Post subject: Re: Vista..oh no! FIXED!
PostPosted: Sat Aug 27, 2011 9:07 am
Thanks for the reply. I got it running and here is what I did:
Installed Vista using the two HP install disks and let the setup program they script run its course...three hours later. :roll:
Finally got into windows! The first thing I did was uninstall anything remotely HP in nature! Then I uninstalled Nortons security suite which crashed while uninstalling :roll: ...but finished anyway...go figure. Then I uninstalled everything Smymantic in nature as well.
Next I went into Start by using msconfig and killed anything HP and Symantic/Nortons including the HP script which they don't list with a HP header...basterds! Make damn sure that one is disabled or sp2 won't install!!!
Once I installed SP2 and it finished I installed Ccleaner and ran the registry section to clean up the system.
Then I rebooted and started Windows Update which is still installing. I also gave him Microsoft Security Essentials for virus protection.
The reason I am going through all this updating and such ...is he is still on dialup and he has cable in the house...try to convince a 86 year old he should upgrade...LOL :roll:
I hope the above procedure helps someone.
Consider this post closed.
PostPosted: Mon Aug 29, 2011 7:14 am
Heh. My granddad still uses 98SE. The only reason he upgraded his printer last year was because we couldn't fix the old one. You're lucky you got yours up to Vista!
