It is currently Fri May 24, 2013 6:48 am
 Post subject: Visual C Installer Random Files
PostPosted: Fri Jul 29, 2011 6:35 pm
Is it just me, or does anyone else have VC extract 40 text documents and .exe's every times you install it? My E:\ has all sorts of "eula.1000" and install.res.1000.dll". It doesn't help that every newly run game on Steam tries to instal VC, which makes this happen every month. Anyone got an idea to make VC calm down and stop setting the top-level of my hard drive as its unpack directory?
 Post subject: Re: Visual C Installer Random Files
PostPosted: Sat Aug 06, 2011 6:41 am
Does the directory get bigger or is the program overwriting old files that are obsolete?
