It is currently Fri May 24, 2013 6:53 pm
 Post subject: Pop up messages
PostPosted: Fri Jun 24, 2011 11:37 am
Anybody know how to, or what app to use, if I want to be able to send a pop up message to another computer on my home network? All computers are using WIN 7.
 Post subject: Re: Pop up messages
PostPosted: Fri Jun 24, 2011 1:34 pm
The right way to do them are via batch files.
PostPosted: Fri Jun 24, 2011 3:17 pm
Do you mean I have to write a batch file EVERY time I want to send a message to another computer?
Net send does not seem to be compatible with WIN 7
PostPosted: Sun Jun 26, 2011 5:17 pm
Malware specialist
Malware specialist
Net send was removed after XP.
You need to use MSG (or WinSent) if you want to do something similar.
