It is currently Tue May 21, 2013 5:11 pm
 Post subject: Change desktop background
PostPosted: Wed Jun 15, 2011 1:47 pm
Hey all...
Is it possible to change the desktop background on Windows 7 Starter? If so how can I do it..???
Thanks in advance...
 Post subject: Re: Change desktop background
PostPosted: Wed Jun 15, 2011 2:31 pm
Malware specialist
Malware specialist
I don't have any computer running Windows 7 Starter, but it looks like this guide should work.
PostPosted: Wed Jun 15, 2011 3:05 pm
Yeah, I already tried that and it didnt work...
When I right click a picture I get the choice to "Set as background" but the background doesnt switch...
I have 2 netbooks running Win 7 Starter..
Kinda sucks.. would upgrade if they met the minimum requirements, but they dont... :(
Still have my other 2 laptops, and desktops, which is running XP Pro on Desktops, and Win 7 Home Premuim on laptops.. Netbook is just easier away from home...
PostPosted: Wed Jun 15, 2011 3:16 pm
Malware specialist
Malware specialist
I don't know what specs your netbooks have, but my Asus 1005HA netbook ran Windows 7 Professional (32 bit version) just fine. Naturally it was slightly slower, but it wasn't too bad.
PostPosted: Wed Jun 15, 2011 9:10 pm
I never did a comparison, or shecked to see what the minimum requirments were.. They might be able to run Win7 32Bit...
Will have to look and see what the minimum requirments are for win 7 32Bit.. and then see if my netbooks will meet those requirments.. The desktop wallpaper is not the only issue I have with the starter version..
Thanks for your help!
Wes~
