It is currently Thu May 23, 2013 10:05 am
 Post subject: a program to quickly uninstall programs you dont want
PostPosted: Fri Jun 10, 2011 12:34 pm
hey im always downloading stuff and i want to know if theres a program that can easily find recently installed programs so i can deleat them easier so i dont have to hunt them down in windows uniinstall a program would be apreciated thanks
 Post subject: Re: a program to quickly uninstall programs you dont want
PostPosted: Mon Jun 13, 2011 10:39 am
I'm not trying to be a smart aleck here but why would you install another app when you can just go to your control panel and do all that...? You could even put a shortcut right to it on your desktop.
I've used 3rd party tools like that in the past but only when I've had trouble that forced me to. Isolated incidents and usually on a malware infected pc, IIRC.
PostPosted: Mon Jun 13, 2011 10:44 am
Greetings,,davidsonasher
There is a very good program to do that ,,it so simple and easy to use
Microsoft Windows Installer Cleanup Utility
The Link: (http://download.cnet.com/Microsoft-Windows-Installer-Cleanup-Utility/3000-18512_4-15905.html)
PostPosted: Tue Jun 14, 2011 8:18 pm
i dont want to use windows because i have about 50 programs to uninstall and i don't want to spend 5 hours clicking each one, windows only lets you uninstall one program at a time
PostPosted: Thu Jun 16, 2011 9:10 am
Yikes. Ya, your first post didn't indicate you needed a mass uninstall tool, you only talked about not wanting to "hunt it down" in Windows, which I did not get at all. But I see what you're dealing with now. 50 huh? I can only imagine...
PostPosted: Thu Jun 16, 2011 7:17 pm
Million Club [PC]*
Million Club [PC]*
You're looking for PC Decrapifier.
It was created as a tool to quickly run the uninstallers for all of the shovelware on a new PC; but, it'll work here, too.
You are still going to need to click your way thru all of the uninstallers - for the most part, Decrapifier doesn't automate the uninstallations - what it does is auto-launch (in sequence, because you can't (un)install more than one program at a time) each app's uninstaller.
PostPosted: Thu Jun 16, 2011 8:07 pm
I like Revo uninstaller for single program uninstallation. The Free version is good enough. There's a pro version that does a lot more, but at a price.
Generally gets rid of all the registry changes and sets a restoral point for you.
Here's the URL if you want to try it:
www.revouninstaller.com/revo_uninstalle ... nload.html
Users browsing this forum: boogeyman8 and 3 guests
