It is currently Sat Jan 31, 2015 12:12 pm
 Post subject: Missing OEM logo from Alienware P.C.
PostPosted: Thu Jul 22, 2004 9:43 am
I have an old Alienware Area 51 P.C. that I'm selling to a friend. I have replaced the original hard drive and upgraded the O.S. and obviously the OEM logo on the system properties is gone. Does anybody know a way to pull the OEM logo.bmp from the original install disk without actually having to re-install the O.S. that came with the P.C. (came with XP Home, upgraded to Pro).
 Post subject: Re: Missing OEM logo from Alienware P.C.
PostPosted: Thu Jul 22, 2004 11:12 am
have you tried searching the cd for OEM.bmp and OEM.ini or OEMLOGO.bmp and OEMINFO.ini ?
PostPosted: Thu Jul 22, 2004 5:24 pm
So, wait a sec. This would show up on the General tab in System Properties? I built my own machine, can I put my own logo there?
PostPosted: Thu Jul 22, 2004 6:50 pm
Yep.
http://www.pcnineoneone.com/howto/oemlogo.html
PostPosted: Thu Jul 22, 2004 8:24 pm
Tried searching the OEM cd, but no luck. The file is probably compressed somewhere or in a hidden folder. That's why I build my own now. OEM hassels. Oh well, if anybody has an Alienware oemlogo.bmp let me know. Thank's
PostPosted: Thu Jul 22, 2004 10:04 pm
its kinda a waste of time...how often to you actually look at the system props?
but if you want, go for it
PostPosted: Fri Jul 23, 2004 5:19 am
You can turn it off and on in the BIOS I think, Correct me If I'm wrong
PostPosted: Fri Jul 23, 2004 8:05 am
You are correct but ksstudios means the logo in system properties ...see the link TWBalls provided for more on how to make your own :)
PostPosted: Fri Jul 23, 2004 3:09 pm
Why not just create your own alienware logo by doing what that guide says? I'm sure you could find any alienware logo off their site. :roll:
