It is currently Tue May 21, 2013 2:44 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Can over 4GB of RAM cause instability with WinXP 32-bit
PostPosted: Sun Jun 05, 2011 6:46 pm
This is probably a common question, but I've never tried or experienced this first hand myself....
I know XP will see 4GB as only 3.5GB or 3.25GB. But what happens if you have a system with 6 or 8GB of RAM (or more)? Will WinXP (32-bit) just ignore the extra RAM, or could this cause instability issues with XP?
I have 8GB of RAM in my system now and want to know before I actually do the dual boot to foresee if there will be any issues prior to actually taking the time to do it.
My reason for doing this is I do programming and want to be able to also play some older games (games that came out prior to Vista, and that don't work with UAC very well). I don't plan to use it as a day-to-day primary OS, just for programming and game playing. Which I can't do in the XP Mode VM, or I would.
 Post subject: Re: Can over 4GB of RAM cause instability with WinXP 32-bit
PostPosted: Sun Jun 05, 2011 6:52 pm
So what wasn't answered in your last thread...
http://www.maximumpc.com/forums/viewtopic.php?f=6&t=112113
PostPosted: Sun Jun 05, 2011 7:14 pm
You'll be fine. Try to stick to one thread on the topic please.
