It is currently Wed Mar 04, 2015 9:07 pm
 Post subject: Win 7 issue - Safe mirror folder copying videos?
PostPosted: Wed Apr 20, 2011 5:41 am
Running windows 7 64 bit (sp1+updates) and I found this folder had a ton of videos in it that I have saved on other hard drives on my computer. By which I mean 86GB of videos.
C:\Users\username\AppData\Local\Safe mirror
What the hell copied them there? Actually I just had a though... I use bulk rename and based on the file names theres a pretty good chance these files were all touched in my bulk renaming... though based on the speed of the program I would have to assume the renaming was being done without copying the files. I'm going to have to check into that.
EDIT: now that I think of it Cobian seems much more likely to blame. I'm going to have to check into that.
Has anyone else seen similar behavior?
 Post subject: Re: Win 7 issue - Safe mirror folder copying videos?
PostPosted: Sat Apr 23, 2011 4:03 pm
Other than the program that needs it, its safe to delete. They made have been placed there in-case something went wrong with the rename. I know some renamers made copies before renaming and then deleted them afterwords. If you haven't already and you don't need them, delete them.
PostPosted: Tue Apr 26, 2011 7:29 pm
Very likely... http://www.sevenforums.com/general-disc ... irror.html
