It is currently Sat Apr 18, 2015 8:14 am
 Post subject: HDD upgrade, can I clone?
PostPosted: Fri Apr 15, 2011 1:50 pm
I am upgrading from a platter HDD to SSD. I currently have 64bit W7home on the machine. The question I have is: Can I simply clone the current 120G HDD onto the 100G SSD? I've tried doing some research and it would appear that there may be issues with the boot sector?
If not, can I at least just make an image of my current drive and write that to the new one?
I'd like to avoid a fresh install and the time of downloading all the updates, if I can.
 Post subject: Re: HDD upgrade, can I clone?
PostPosted: Sat Apr 16, 2011 11:19 pm
Mr. Late Night
Mr. Late Night
That depends. As long as you aren't using the full 120GB of your current hard drive you should be able to do the type of clone. The ones where you "shrink" the drive tend to be on the iffy side but if you're going from say 75GB on the mechanical hard drive to 75GB on the SSD you should be fine. Acronis True Image should be able to handle the job nicely.
PostPosted: Sun Apr 17, 2011 8:39 pm
Last I looked, I'm actually using around 40G, so it definitely won't max it out.
Thanks I'll look for Acronis.
PostPosted: Tue Apr 26, 2011 7:30 pm
+1 for True Image. I Love that software.
