It is currently Tue Mar 31, 2015 5:35 am
 Post subject: Windows Vista Internet Explorer 64 Bit
PostPosted: Sun Apr 03, 2011 8:57 am
I deleted my shortcut icon from my start menu to open Internet Explorer 64 bit. Now I can't find it anywhere else, or the actual application icon. Does anyone know where to find the 64 bit explorer in the PC? I have 2 Internet Explorer folder locations in my C drive. One is marked Program Files X86 and the other just says Program Files. Is one of these for the 64 Bit? If so, how do I tell if the explorer is actually 64 bit? I tried looking in the help area (about Internet Explorer), but both only says 256 bit. Nothing about 64 bit? Maybe its in another location? Any help would be appreciated. Thnx
 Post subject: Re: Windows Vista Internet Explorer 64 Bit
PostPosted: Sun Apr 03, 2011 6:31 pm
Million Club [PC]*
Million Club [PC]*
%program files% contains your 64-bit native programs; %program files (x86)% contains your 32-bit programs.
So, the IE that's in C:\Program Files is IE 64-bit; the IE that's in C:\Program Files(x86) is IE 32-bit.
And, and FYI: The Search function in the Start menu can find them, too. Just type internet explorer there, and you'll see IE, IE (64-bit), and IE (no add-ons) listed. ;)
PostPosted: Wed Apr 06, 2011 4:01 pm
Thnks!
