It is currently Tue Apr 21, 2015 12:36 am
 Post subject: Change Win 7 Hotkeys?
PostPosted: Wed Mar 02, 2011 1:53 pm
Does anyone know how to change the windows 7 hotkeys? I severely dislike the current way they have "ctrl alt del" as the window for account management, I want it to open up my task manager.
I know that the Task manager can be opened by like shift/win key + control + escape but... That's too irritating of a key combination. Ideas anyone?
 Post subject: Re: Change Win 7 Hotkeys?
PostPosted: Thu Mar 03, 2011 6:37 am
Instructions:
http://tinyurl.com/change-win-hotkeys
PostPosted: Thu Mar 03, 2011 8:31 pm
That's only for disabling not changing them, thanks for the help though!
PostPosted: Thu Mar 03, 2011 8:52 pm
New one on me. Right click the task bar and select Task Manager or CTRL+Alt+Del and select Task Manager. Wat's the problem?
PostPosted: Fri Mar 04, 2011 12:59 am
Old habits die hard. I also prefer keyboard use over mouse clicks. :( But I guess I'll live.
PostPosted: Fri Mar 04, 2011 5:37 am
The link tells you how to enable and disable the hot keys...read the whole article.
PostPosted: Wed Mar 23, 2011 10:34 am
Step 1: Create Shortcut to Task Manager
Step 2: Right-click Properties
Step 3: Put in the shortcut text box your combination
Step 4: ???
Step 5: Profit
(Or just thumb on ctrl, pointer finger on shift and middle finger on esc. Unless you have small midget hands this won't work)
