It is currently Sun Jan 25, 2015 3:25 pm
 Post subject: How do I keep my programs through an upgrade?
PostPosted: Wed Feb 23, 2011 10:51 pm
I'm upgrading from XP to 7 as soon as they fix the auto-arrange in folders and I wanted to make sure I could keep all my art programs when I do. I have one called Illuststudio that's exclusively Japanese but I bought and got it installed. Problem now is I can't seem to locate the license for it. How can I keep the program through the upgrade?
 Post subject: Re: How do I keep my programs through an upgrade?
PostPosted: Thu Feb 24, 2011 10:48 am
Short answer: you can't.
When you install a program, it makes changes to system files that will be wiped out when you reinstall the operating system. Worse, those system files are different between Windows XP and Windows 7.
PostPosted: Thu Feb 24, 2011 11:11 am
Would you know how to at least find the license somewhere in my program files?
PostPosted: Thu Feb 24, 2011 11:21 am
That is application dependent and I've never heard of the app that you're using .. sorry.
