It is currently Fri Apr 24, 2015 11:44 pm
 Post subject: Looking for a free PDF maker via printing
PostPosted: Wed Feb 16, 2011 6:00 am
Hello all,
I hear you can install an app that allows you to print "whatever" to PDF files.
Will appreciate a recommendation that meets the usual criteria:
1) free!!!
2) free of bloat / ads / crud / etc!
thx for reading :)
 Post subject: Re: Looking for a free PDF maker via printing
PostPosted: Wed Feb 16, 2011 9:13 am
PDFCreator
http://sourceforge.net/projects/pdfcreator/
PostPosted: Wed Feb 16, 2011 9:41 am
furball146 wrote:
+1. Good stuff, it works. Look no further.
PostPosted: Wed Feb 16, 2011 11:58 am
i see it installs a toolbar which can be annoying to remove?
so one should instead do a CMD install such that:
PDFCreator-1_2_0_setup.exe /SILENT /components=\"!toolbar\" /tasks=\"!desktop_icon\" /f /norestart\
Anyone experienced with install of the latest version?
PostPosted: Wed Feb 16, 2011 12:07 pm
wow, that install method per CMD was for older versions...
Just read to install without toolbar, you need a build a custom INF file for the install... geez....
http://www.pdfforge.org/forum/open-disc ... no-toolbar
I'm assuming the recommendations for the app predate the inclusion of the toolbar it now installs...
PostPosted: Wed Feb 16, 2011 8:03 pm
You may also want to look at CutePDF Writer.
PostPosted: Wed Feb 16, 2011 8:34 pm
Works great. I've used it for several years with good results, and it's free. Then replace Adobe reader with Foxit, also free (although they do have a pro version that requires payment)
PostPosted: Thu Feb 17, 2011 5:17 am
I use PDF Creator all the time on many machines. I have NEVER had a toolbar installed. Read the thing and don't get click happy. Just don't agree to the toolbar terms and it doesn't get installed.
PostPosted: Fri Feb 18, 2011 3:20 pm
Windows 7 Pro Outreach Team
If you have Microsoft Word 2010, you can save your docs as a .PDF file and you can probably print it accordingly.
-- Ryan
Windows Outreach Team
PostPosted: Sat Feb 19, 2011 7:44 am
I've noticed MS Office Basic 07 can save to PDF as well as Open Office, which is free.
PostPosted: Sat Feb 19, 2011 10:39 pm
I vote for CutePDF as well. I've used it for years and love it!
Hope this helps.
PostPosted: Sun Feb 20, 2011 12:04 pm
While it's a great single solution to a single question (CutePDF) , we all need some sort of suite don't we? CutePDF sounds like a great alternate to Adobe or FoxIt readers, why not get a suite that does it for free too? Notepad is cool and all, but only goes so far.
I know, I know...it's beyond the exact question and isn't the exact answer. But feel it's a better answer in the long run. Otherwise, I'm back to free FoxIt which has no ads thus far.
