It is currently Sun Mar 01, 2015 3:54 am
 Post subject: Win Vista HP Can't Upgrade All........
PostPosted: Thu Feb 03, 2011 5:15 pm
Running Win7, crashed and had to reformat. Win7 was an upgrade so I used the Win Vista HP dvd to format the C drive, then install Vista.
I need to upgrade Vista before I install Win7 and for some reason, many updates won't install. Out of 120 updates, I only got 40 installed. Now......Windows Update is telling me it cannot search for any updates. How can Windows NOT be able to search for updates???? What to do??????
 Post subject: Re: Win Vista HP Can't Upgrade All........
PostPosted: Thu Feb 03, 2011 6:45 pm
are you installing the drivers off of the vista disc, while in windows 7?
Windows 7 might have "generic" drivers for some things, but i think it might be best to use the ones from HP
PostPosted: Thu Feb 03, 2011 8:07 pm
Amazingly enough, this was answered to you some time ago...
viewtopic.php?f=6&t=99323
and answered in your reformat thread...
viewtopic.php?f=36&t=110948&p=1135601#p1135601
Is there a reason you're asking this again?? :roll:
PostPosted: Sat Feb 05, 2011 4:25 am
Yea, I'm past all of that now.
I am successfully running Windows Vista HP on my pc NOW. When I try to download updates I can only install a few out of the 120 needed before I try to upgrade to Win 7...... you follow now????
Try to focus on the problem at hand then waste time digging through my old posts......
PostPosted: Sat Feb 05, 2011 1:38 pm
Really? If you want help you shouldn't be so rude.
PostPosted: Sun Feb 06, 2011 12:00 pm
If someone doesn't understand the question or can't answer the question then they shouldn't respond.
Pretty obvious, I know, but I guess someone had to say it.
PostPosted: Tue Feb 15, 2011 5:35 am
Have you validated vista yet,i know sometimes you cant download some updated if your copy isnt validated.
PostPosted: Thu Feb 17, 2011 1:32 pm
What I think happened is this.
I'm running a 60gig SSD as my C drive. Nothing on it but OS and a few proggys that's it. SSD is old technology used in a new way. My pc does a lot for me when I use it. Plays HD media on my 42" HDTV while I am on the internet, runs internet media too at the same time if needed. I think I corrupted the SSD somehow which in turn corrupted the OS.
When I put in Vista, I did a format and got all my 60gig space back. Freshly installed Vista, downloaded and installed 95% of the required upgrades. Started to upgrad to Win7 but 20 minutes in I get a corrupted file message and everything reverts back to Vista.
Thought the problem the whole time was the OS but with a format and a fresh install, that shouldn't matter. Now I believe it some part of my SSD is corrupt which is why a fresh install of Vista still didn't work. I guess my only remedy is a new drive which are plummeting in prices. The new thing seems to be the PCI-E SSD's with their 540MB/s speeds that are bootable.
My last 60gig SSD from a year ago cost $225 and now I can get it for $128. 50gig PCI-E SSD goes for about $250 but seems to be the future.
Unless someone out there has a better idea...............
PostPosted: Fri Feb 18, 2011 1:29 am
Using google, under a minute found this.
PostPosted: Sat Feb 19, 2011 11:19 am
Simplified:
If you plan on running Win7, you don't need to update Vista at all. Install Vista, don't do a single update, and go instantly into Win7's install/upgrade. To update Vista means you're going to run it, and you're not. Many of the updates will be redundant to what's already in Win7 by default. All the upgrade requires is to run it from a working Vista...not an up to date Vista.
The question then reverts to the Win7 install crashing and not much more. Vista updates aren't curing this for sure, so just stop there. If Vista installs fine, so should Win7.
Is AHCI enabled in the BIOS giving Win7 the ability to treat it correctly? This is something XP and Vista didn't give a rat's caboose about.
PostPosted: Mon Feb 21, 2011 4:29 pm
WOW......great reply Chumly. Looks like you may have hit everything on the head. I've been happily using Vista as of late since it does all I want my pc to do so I'm content.
Great thinking on the upgrades/updates.....most are probably already installed on the Win7 upgrade dvd.
I'm gonna check that bios setting and see the effect it has. I have a 3.2 chip running at 3.6 by changing a few settings in bios. Will post results and thanks again.
