It is currently Sat May 18, 2013 7:28 am
 Post subject: Exporting Contacts
PostPosted: Sun Dec 26, 2010 1:17 pm
I have Vista Home Premium How do I export my contact file to an external drive. Thanks.
 Post subject: Re: Exporting Contacts
PostPosted: Sun Dec 26, 2010 3:10 pm
There's a contact folder in your user folder. If you running winmail they should be in there. If you running winlivemail then u click on contacts in wlm and hit export on the menu.
PostPosted: Mon Dec 27, 2010 4:29 pm
Sorry for being so dense. I can't find the export option. I have File, Edit, View, Tools, Help on the Contacts Menu. I'm running Windows Mail. Is the export option in the Contacts section or in the Windows mail menu?
Can't find export in help either. Thanks for any help you can give.
PostPosted: Mon Dec 27, 2010 4:36 pm
Never mind. I found it in the main Windows Mail toolbar, File option. Thanks again.
